Buderus G315/7
Weezbo
Member Posts: 6,231
so we can lose the old oil systems and hook some nat gas Riello burners...You one luck sonna gun *~/:) those are some cool burners.
Buderus G315/7
Any of you guy's used any Buderus G315/7 boilers?
I have a job I might use two of them on with Riello modulating gas burners and wondered if anyone had any feedback on them.
S Davis
Apex Radiant Heating0 -
I've used many on Nat gas
and they work perfect. We have them as high as 9,000 ft. elevation!0 -
Question,
Are these for 2 seperate homes or for something in the same building ? What's the control strategy? Where are they going to be used?
Are you going to do lead/lag or use one boiler for a main and pick up the extrenuous load with the second, if they are for a single space ?
The boilers are , without a doubt TOP NOTCH. The control use is the second and most important part of the big picture. How and why they are being used would be the deciding factor for me.
Fine boiler, give us the details and someone might be able to let you in on the facts. You might be able to accomplish the duties with something smaller and less costly, thereby guarenteeing you get the job.( I always tend to think long term....) Chris0 -
can you...
down fire them?..the lit. says max firing rate. On the 5 sec. it would be nice to go a bit smaller w/o droping down to the 215 series...kpc
apartment building
They are for a apartment Building it is a change out and they will power two ST400 tanks for domestic water and cast iron rads for building heat, I am planning on using the 2107 control with the FM242 module to control both boilers.
S Davis
Two Stage
They are set up so you can have them run two stage or modulating burners I have been told.
S Davis
- 120 Geothermal
