I have air promblem with 2 tanks I get my hot water from the sun
Weezbo
Member Posts: 6,231
therein lies the minor technicalities.i dont mean to sound cold about it buh thats my story an i am stickin toit.
Air in water tank
My brother lives in N Calf and make hot water by use of solar and a hryo log in the fire place. the water is heated and sent to a holding tank then sent to the electric water heater tank into the cold water line. Air gets into the domestic tank and lowers the system pressure so that he has to hook a hose to the tank drain an bleed the air out to get the pressure back is there a way to bleed the air off before it gets to the tank. I is regular water heater tank with a 3/4 " cold water inlet.
Thank you George P Gallo Plumber on L.I. New York0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 944 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
