radiators that just will not get hot
mike d_2
Member Posts: 2
i have ahydro boiler and it has about 6 radiators the first 3 get hot but the last three do not I talked to a rep he told me that I could pipe them in a loop 3/4 foster pex in to one out to the next i had problems so he told me to put a bigger pump on I did that it did not work so I made sure that i did not tie in to the first floor loop i did not but i can not get to one half of the system could i split the system to two zones 3 rads on one loop and 3 rads on the othere
System
What kind of system is it? Steam or water
RADATIORS
WATER HYDRONIC0 -
how big
> WATER HYDRONIC
how big are the radiators, how big is your boiler, btu's wise. did you bleed the air out of the system,is there air in the radiators,are there valves in the rads,and are they open,when the pump starts to run are you getting cold water on the return, is it a single or split loop system ??
these are some things that should start you in the right direction0 -
first to feed...
how about this simple rule when dealing with multiple radiators in a zone... (first to feed,last to return)0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 943 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
