spirotrap dirt separator
grindog
Member Posts: 121
Has any one installed the dirt separator offered by spirovent. It looks like a good product. Where would you install this on the supply or the return?
Spirotrap
I don't think it matters. On bigger diameters they sell a combination unit that is both a SpiroVent and a SpiroTrap. They probably should for the smaller sizes too, although they would then probably have to change the design a bit so that it has an expansion tank provision. Since the SpiroTrap costs almost as much as a SpiroVent, it would be far cheaper and simpler to install it that way. As well, it would only cost about 25% more.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
