Radiant heat manifold size
Geo_4
Member Posts: 10
I'm installing a 1/2" pex stapleup system in 2- 600sqft areas, each with their own zone. I'm running a 1" feed and return off my primary manifold to that area. I was going to use a common system pump with z-valves for each zone. Each zone will be heating 600sqft, new construction. Can I use a 3/4" manifold out across the basement for my supply and return for each zone or will I need to use 1"? The 3/4 would be cheaper but I want to do it right. Any help would be great. Thx
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
