Hot Water Heater
Mel_2
Mel_2 Member Posts: 12
I'm planning on replacing my 40 gal hot water heater (gas) with a 50 gal tank. Anyone have information on which are the best models/most efficient tanks to buy? Not sure whether to just get one from my local home depot or buy from a plumbing store?
  • Robert O'Connor_7
    Robert O'Connor_7 Member Posts: 688
    Mel.
    Buy it from a plumbing supply house...Robert O'Connor/NJ
  • Al Letellier
    Al Letellier Member Posts: 781
    water heater
    Ditto on the supply house. Remember this. A larger tank will NOT give you more hot water, necessarily. It's the BTU input that really counts. A 40 gal, 30K heater will only give you a few more gallons of hot water than a 30 gal, 30K heater will. There will be a little less recovery cause it has to heat more water. So if you go to a bigger tank, talk to a pro (not a sales clerk) about higher recovery and BTU input on your larger tank.
  • Larry Weingarten
    Larry Weingarten Member Posts: 3,676
    heaters come with...
    ...a "first hour rating". That is how many gallons they can deliver in one hour starting with a fully heated tank. That's the number you need to compare rather than gallons.
    Yours, Larry
  • Bruce M.
    Bruce M. Member Posts: 143
    On Demand Hot Water Heater
    You might want to look at a Noritz or Rinnai tankless on demand hot water heater. They will give you hot water at a lower operating cost
