TACO radiant block has anyone tried it and how was it ?
Mark_16
Member Posts: 4
We have used a couple and they work well. Just read the instructions thoroughly before installing and all will go smoothly. I believe there was a thread on the Mixing Block just recently here....do a search and you should find it.
-Jared0 -
its up town *~/:)
in the 4 plex ;out on snob hill, in my spec radiant,out in the country, an bought my buddy 6 new radiant jobs next year,shall i continue?0 -
Installed 2 to date and they are great , especially for existing boiler applications.
PATRIOT HEATING & COOLING, INC.
We have purchased 4 of them. They seem to work good. Try www.patriot-supply.com if you have trouble finding one.0 -
Instruction sheet
For your reference I atached the instruction sheet.
Taco, Inc.
Joe Mattiello
Technical Service Technician
joemat@taco-hvac.com
401-942-8000 X 484
www.taco-hvac.comJoe Mattiello
Taco Comfort Solutions0 -
thank you Joe for the manual, It will be very helpfull.I am thinking of trying one on a radiant job i am on now.0 -
Mark, i took some pics today. of some pump blocks ....
A friend of mine installed ...hes happy with them as they saved him lots of time..we share ideas around our neck of the woods and have decided that were we to designe it , there are a few things we would want added to the pump block,one is a vynil hose off the top of the air eliminator to vent and redirect any possible water from leaking down onto the pump block and its electrical Brain board...the other would be another means of connection to the board,...another would be a side compartment on the top right for low voltage(sensor) connections..and as i am currently bolting one to a plate there are a few things that i have yet to Discover on the wayone thing id like to suggest is that you fully purge the fields and system side prior to installing them...not knocking anyone ...however..two of them have a distinctive cavitation growl so when i came over to fire the boilers and noticed it i asked if they had been purged properly,....well, sure he says,...well, when i noticed it it seemed that the thing to do was put more water into the system ,just in case, that seemed to help, buh, maybe its just me,,,none of the ones my other friend or i have installed do that.so, purge every thing well.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
