Looking for simple Power vent Boiler 300,000 input....Boilerpro
Boilerpro_3
Member Posts: 1,231
Looking at a mid size commercial job which I want to use two simple stage fired hot water boilers that are power vented. The largest I have been able to find are the Dunkirk XEB models @ 225,000 input, would like about 300,000input. I am trying to stick with iron to avoid the touchiness of copper tube. They also may need to run at higher temps, say 220F, because they will be feeding converted steam coils in a couple of air handlers. So far the only solution I can come up with is to use 2 atmospheric vent boilers and add power ventors to them. Also a total equivalent vent length of about 40 feet is necessary.
Any Ideas?
Thanks all
Boilerpro
Any Ideas?
Thanks all
Boilerpro
Any luck?
perhaps there is a small commercial powered vent and go with two boilers...0 -
have you checked Buderus?
I'll take a look..Thanks!
Just put in a Clever-Brooks....
and quit goofing around with those silly little boilers. Hi BP, I couldn't resist.
Art0 -
Hey,Great to hear from you!
Hope all is going well with you and yours!
Dave0 -
Smith boiler
has a comercial prssurized CI model that can use an oil or nat gas (powerFlame) forced draft burner. 3 section starts at 300K BTU. I'm afraid to ask how heavy it is.
http://www.smithboiler.com/html/G19A-4.pdf
I think the Burnham V9 is the same design and they also have the FD series steel unit that's gotta be a lot lighter.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
