Radiators and valves are leaking?
Aaron Hovel
Member Posts: 7
I have a one pipe steam system. We set our thermostat back 5 degrees during the night for comfortable sleeping and energy savings. I have noticed that during the first morning cycle, many of the room radiators are leaking, where as they don't leak during the normal day cycle. I'm assuming that is because the first morning cycle takes longer. It has to go from 57 to 63. This causes the pressure to build up in the system and exploits the leaks. Where the normal cycle does not build up the same amount of pressure. Most of the leaks are occuring on the stem of the supply valves. Some of the leaks are on in some other areas of the supply valves.
My question is:
1. Is the fix just simply repacking the supply valve stem or is there something else wrong with my system?
2. Also, if the supply valves are leaking at other places, besides the stem, is it easiest to just replace them?
Thank you,
Aaron
My question is:
Thank you,
Aaron
repack
Repack all the stems and see what happens, when you have colder rads you have more quick condensation, and if your stems leak water they leak air which should be venting from the rad vents, also check the rad pitch to make sure the condensate is completely draining.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
