Clips for suspended MultiCor
Ewan
Member Posts: 45
for the reply... much appreciated.
Is it the Wirsbo Tubing Clip 1/2", 5/8" (PN 7051258) you're referring to?
I'm a homeowner currently working on the distribution piping for retrofit hydronic baseboard installation. The system has been designed by a reputable and professional radiant design firm and I'm hiring a contractor for the boiler installation and gas work.
I have a tiny section of suspended-tube under the bathroom for floor-warming only (a baseboard emitter handles the heat loss). The suspended-tube section is simply the MultiCor return from the baseboard, run through a couple of joist cavities.
I'm looking for suspended-tube clips that will work with MultiCor (which I understand has a slightly larger OD than hePEX).
Any suggestions from the pros?0 -
clips
Either Clixclips from Wirsbo OR get the Lock Down clips from Watts (prder #81000818 pn#P667100-100)0 -
yup
Ewan,
Thats the one. Very nice clip.
You can also use the Magione FD05 series of stand off clips too. (forgot that one earlier).
Steve0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
