convector BTU ratings????
jesse the great
Member Posts: 72
Does any one have a chart on the BTU ratings of hot water convectors??? Im bidding a job and i dont know the ratings any info would be great . thanks
Check the maker's web site
Average baseboard is about 550 BTU/ft @ 180° water, but there's high output baseboard and some low profile stuff that will do less, so you're best bet is to check the manufacturers web sites.0 -
Convector Ratings
There are Convector Ratings in the Burnham Heating Helper. It is available for viewing on line at the link below in .pdf format. The convector ratings are on page 45. You will need to know height, length and depth of the convector cabinet. Hope this helps.
http://www.burnham.com/pdfs/htghelper.pdf
Glenn Stanton
Manager of Training
Burnham Hydronics
www.burnham.com0
- 86.7K THE MAIN WALL
- 57 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
