Suntec pump needed
Terry H.
Terry H. Member Posts: 73
I have a customer in need of a Suntec J3NBN-D132B oil transfer pump. Suntec says it'll take 8-10 weeks to get. If anyone knows of someone with one in stock I would greatly appreciate the heads-up.
Thanks-A-Lot
Terry H.
  • Firedragon_4
    Firedragon_4 Member Posts: 1,434
    Sid Harvey's and where
    are you located????
    That's an unusual pump BTW, why not use an H3 it's two-stage that J3 is only single.
    What's your pressure on the system? The J3 is 40-80 psi rated, you might sqeak that out of a regular res. pump by turning it all the way down.
    Check for more info here:
    www.suntecpumps.com
    Sometimes you need to do a little homework yourself.
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Mr. Dragon,
    You beat me to the punch!
    Sid's carries quite an array of new and "remanufactured" fuel units and can get them there fairly quickly too! Chris
  • Bill_48
    Bill_48 Member Posts: 1
    Patriot Supply
    One of the best supply houses for commercial equipment is Patriot Supply in Plainview NY. Give Joe, Jim or Steve a call at 516-249-3100, I am sure they will be able to help you out.
  • Joe Moody
    Joe Moody Member Posts: 22
    Pump
    I just got one from www.patriot-supply.com they had a few in stock. They shipped it out right away. Good Luck!
