wide plank floor w/ radiant
tim smith
tim smith Member Posts: 2,843
Just a ??, you guys seen any problems to speak of with 6" quarter sawn white oak floor over radiant tube with Gyp, using proper temps on water and proper 80 degree surface temps. Just checking. Thanks Tim.
  • Constantin
    Constantin Member Posts: 3,796
    Have a look over at...
    ... launstein.com and the hardwood council. They have very good recommendations that cover all things hardwood on Radiant floors.
    If you want to go truely bomb- and crack-proof, I have heard that building a floating floor can do the trick. Such floors are not attached to the underlying joists and "float" above, with some room around the edges hidden under the baseboards to accept expansion and contraction.
  • harvey
    harvey Member Posts: 153
    7\" wide maple floor
    7" wide maple flooring over sub-ray. engineered floating floor. No problems at all to date 2 yrs.
  • tim smith
    thanks for the reply
    Can't do floating floor, needs to be gyp and sleepers. I am not to crazy about the customers selection of 6" wide oak in this. I have given him the information from hardwood council as to the concerns over wider than 3" boards. Up to him now.
  • S Davis
    S Davis Member Posts: 491
    Floating
    Maybe floating but I would run away very fast from sleepers and wide plank.
    I did one with 8,000 square feet of ten inch wide plank but it was a floating floor with two sheets of 1/2" opposing plywood and the wide plank nailed to that it did really well, but I have seen wide plank on sleepers that looked horrible.
    S Davis
    Apex Radiant Heating
  • John Felciano
    John Felciano Member Posts: 411
    Watch
    The moisture content of the hardwood AND the gyp it sometimes takes a long time for the moisture levels to be at an acceptable level.
    Will the customer object to small gaps in the flooring or does he expect it to be perfectly seamless?
    Have you looked into "dry" systems rather than the gyp?
  • tim smith
    I agree, documentation to bldr yesterday.
  • tim smith
