wierd code on pinnacle
Gary Jansen_2
Member Posts: 26
My distributor called me wanting to know if I have ever seen a "NC" code on a new pinnacle boiler with the P125 board, not the old wha board. Calls to the man rep just got a shrug of the shoulders, call to Peerless were not returned as usual. Any ideas? Thanks, Gary
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=156&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
\"nc\"
is a temporary loss of neutral. It is an electrical issue with the wiring feeding the boiler. It usually happens when power is returned after a loss. There is power on the circuit board, but not a return leg. Like any computer, you may have to protect it with a surge protector, or most likly a UPS. If power outages are frequent in the area.
Hope this helps,
Chuck Shaw0 -
If a neutral
If it is a neutral problem make sure the power feed goes only from the panel to the boiler. I have seen shared neutrals in old basements cause alot of headaches.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 968 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 44 Industry Classes
