indirect hot water heaters
grindog
Member Posts: 121
my customer wants a new high efficiency heating system with at least 80 gallons of hot water for his summer house. to heat the house requires 70,000 btus. I have sold him on a munchkin boiler with a 80 gallon super store. My question is, being that this is a summer residence would it be better to install a 40 gallon super stre with a storage tank piped with a recirc line or install the 80 gallon tank with it set on priority. I just want the most efficiency and enough hot water for the customers needs.
my customer wants a new high efficiency heating system with at least 80 gallons of hot water for his summer house. To heat the house requires 70,000 btus. I have sold him on a munchkin boiler with a 80 gallon super store. My question is, being that this is a summer residence would it be better to install a 40 gallon super store with a storage tank piped with a recirc line or install the 80 gallon tank with it set on priority. I just want the most efficiency and enough hot water for the customers needs.0 -
Go with the 80 gallon...
after you get done with the storage tank and bronze circ. you won't be that better off. Are you using the Contender or the Ultra. I use the Contender a lot. The 80 gal. is a very good value...kpc
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
