Radiant from the hardware store
Carl PE
Member Posts: 203
about 10:00 last night to get some pvc fittings. Had to do some emergency plumbing in my basement.
I'm going to be nice and not reveal the name of the store.
Anyway, I was roaming around their plumbing department, checking out the Sioux Chief manifolds, when I saw this flier (see attachment).
Comments?
Comments?
Can you change the format of the pics.??
Apparently I don't have anything on my 'puter to open the .tif files. JPEG maybe????
thanks
Floyd0 -
JPGs
well done. I know we tell all our clients with "Poor" insulation that they need 150 BTUs/sq ft of heat source to heat their house. You guys all do that too, right?
Surface Temp
If the room set point was 68 they would only need a floor surface temp of 143 or so to deliver 150 btu/sqft. Ofcourse the other side of it is that they can not move that kind of energy so the heat source will short cycle like crazy.
Tim D.0 -
Hey now, come on. Our job is to make sure the clients are covered and this way if they forget to put a roof on the house, we can melt the snow in their living room if necessary!!!!!
With 150 btus a foot,
i venture to say i could heat the sinuews out of there overely tight shoes:)And Cook them))
How about..
1> Using a water heater as a boiler (it's not the same thing, you know)
2> The open system in Figure 1 (which might possibly kill you)
3> The control panel with one pump, and one 3-way valve.
More info on CPI...
http://www.durapex.com/heating.asp
It'll make the hair stand up on the back of your neck...
ME0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 944 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
