Fresh air pipe for Riello BF5
Weezbo
Weezbo Member Posts: 6,231
you are using 4"or 3" cool go with it.
  • Does anyone know
    the maximum distance the fresh air pipe can be run for the BF5 ? I'm planning on a horizontal run about 8 to 10 feet , using PVC to within 2 feet of the burner . Then I'll transition to a flexible dryer vent with the special draft regulator in there somewhere . I might have to double 45 the PVC to get around a wall also . Thanks for any help .
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    you should ...
    be fine with 10 feet. In fact some direct vent mfg.( I realize that you are not doing a direct vent) suggest that if you have very cold temps outside that you should run at least 10 feet to warm up the intake air. I have heard of some problems as of late associated with low temps and direct intakes due to cold intake air....kpc
