Banging steam heating pipes
Bob L
Bob L Member Posts: 2
I have a steam radiator system heated with oil, the furnace is 4 years old and maintenanced by the oil co. yearly. however, I have a banging in the whole system when the heat comes on as far as I can tell the return pipes in the basement are pitched back towards the furnace. The furnace is in the middle of the basement and it sounds like I have banging on both sides of the house. How can I eliminate this banging problem?
Bob L
  • ed wallace
    ed wallace Member Posts: 1,612
    banging pipes
    look up find a pro evedently the oil co does not understand steam heat where are you located
  • 1st thing
    Can you post some pictures of the boiler here ? Maybe we can give you some helpful hints to get you pointed in the right direction .
  • clammy
    clammy Member Posts: 3,213
    contact your oil co
    Have you contacted your oil co just because you get and have a yearly burner contract doesn,t mean the mech. is staying long enough for the complaint you suggest arrives .Sounds like you have counter flow system possilble some one has set your pressuretrol to high or some of your mains or rads have lost some pitch over the years by the way are your mains insulated or bare metal .PS have you called and complained to your oil co ? good luck and peace clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
