thermal efficiency of old boilers
Ted_4
Member Posts: 86
> What is the easiest way to check thermal <BR>
> efficiency of existing old boilers. I understand <BR>
> the basics but trying to figure the most accurate <BR>
> but not overkill way of doing it. Thanks in <BR>
> advance. <BR>
<BR>
> advance. <BR>
<BR>
thermal efficiency of old boilers??
What is the easiest way to check thermal efficiency of existing old boilers. I understand the basics but trying to figure the most accurate but not overkill way of doing it. Thanks in advance.0 -
Efficiency Test
If by "thermal efficiency" you mean combustion efficiency, the easiest way is with a digital combustion analyzer such as a Bacharach Fyrite Pro. This tester (or the older manual types)will give you an idea of how much of the heat from the fuel burned is going up the stack, and how much is being made into useful heat.
Finding out the "seasonal efficiency" (what percentage of the heat produced is actually making it to the living space) is a lot trickier, and depends on where the boiler is located, the amount of jacket insulation, the amount of burner run-time, etc.
We find that the perfomance of older boilers can often be improved noticably by cleaning the heat exchanger,improving the burner or burner tuning, and reducing the firing rate. All these improvements are immediately shown by combustion analysis.0 -
efficiency
Ted, thanks for the reply, combustion efficiency is one we do all the time but thermal, or in your term seasonal is the one I am trying to figure the best way to measure. Thanks again, Tim.0 -
Makes you wish...
... you could have two strap-on flow meters (ultrasonic), two thermometers, to figure out the flow of BTU's into and out of the boiler. Monitor the intake of gas or oil, then figure out the difference.
The flue gas approach is cheaper and easier, no question. However, a actual flow analysis would settle once and for all what BTUs are being sent into the building vs. being lost on standby, etc.0 -
flow analysis and temps
I have the ashrae calculations to figure the thermal efficiency. Hardest part is getting ahold of the ultrasonic meters for flow, a costly proposition. Can't justify buying one. May have a company I know come in with his test and balance equipment to do this. Still $$ but may be worth it on some jobs. Thanks for the replies all. Tim0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 944 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
