Paging Jason...
BillW@honeywell
Member Posts: 1,099
Bump to the topof the list
Your call...
The phone number you gave me was garbled, so I couldn't call you back. Yes, Honeywell makes air eliminators, they are part of our water products line , and should be available from any hydronic oriented Honeywell distributor. They are called Powervents and are an improved design over the older models, featuring a stainless steel air bubble concentrator and a solid plastic float that's impervious to water or dirt. They are available in sizes from 3/4" to 2" and we even have commercial units in sizes up to 8". For a tech sheet, go to http://hbctechlit.honeywell.com, and type in PV075 for a tech sheet. No password required and the site is free.0 -
thank you very much bill i will buy one0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 944 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
