Gas logs
JimGPE_3
JimGPE_3 Member Posts: 240
I have always heard that if a gas log has yellow-tipped flames it is because there is incomplete combustion and CO is being produced. For that reason, if you want some yellow flames for aesthetics reasons, it needs to be a vented fireplace.
I took my CO Experts detector over to my daughter's house, fired up her un-vented gas log, complete with yellow tipped flames, and in half an hour I was unable to detect any CO whatsoever in the room.
What am I missing?
  • Dale
    Dale Member Posts: 1,317
    Input
    If you checked over the flame with a co detector meant for quick response in a flue you would see some co. The way the unvented stuff get's the ok is to keep the input low and if you read the fine print you're supposed to keep a window open when using it. And of course there's the moisture issue.
  • JimGPE_3
    Um, ahem....
    Did I mention this was my DAUGHTER'S fireplace?
    I have a fully vented, wood burning version at my own home for that sort of activity....
  • MIKE6
    MIKE6 Member Posts: 102
    no co
    I've checked several gas log sets vented and unvented all had no co or very little.2-6-ppm in the flame.Boilers with ayellow flame put out over 900ppm.
  • MIKE6
    no co
  • Weezbo
    Weezbo Member Posts: 6,231
    a vent.
    meaning a vented appliance.
  • Mijola
    Mijola Member Posts: 124
    Vent Free fireplace
    Jim,
    Follow the link to HVAC Talk. This is the Fireplace section. Ask over there from the professional fireplace techs their opinions regarding vent free gas products. Or do a search on "Vent free" or "unvented". It will be a real eye opener. BTW, you will see my posts there on the topic.
    http://hvac-talk.com/vbb/forumdisplay.php?forumid=4
    Regards
    Ed Carey
  • Mijola
    Vent Free fireplace
    Jim,
    Follow the link to HVAC Talk. This is a link to the Fireplace section. Ask over there from the professional fireplace techs their opinions regarding vent free gas products. Or do a search on "Vent free" or "unvented". It will be a real eye opener. BTW, you will see my posts there on the topic.
    Regards
    Ed Carey
  • Mijola
    Vent Free fireplace
    Jim,
    Follow the link to HVAC Talk. This is a link to the Fireplace section. Ask over there from the professional fireplace techs their opinions regarding vent free gas products. Or do a search on "Vent free" or "unvented". It will be a real eye opener. BTW, you can also search my name and you will see my posts there on the topic.
    ps, Put on your hard hat before entering.
    Regards
    Ed Carey
  • Mijola
    Vent Free fireplace
    Jim,
    Regards
    Ed Carey
  • Mijola
    Vent Free fireplace
    Jim,
    Regards
    Ed Carey
