Solar heat
MT
Member Posts: 21
My friend has a 75g electric water heater that feeds the house in the winter. Than it has a little tank that runs off of the water heater with two circulators that work a solar panel on the roof wich I am guessing runs only in the summer? Does anybody know about this type of system, and do they know where I could learn more about solar heating. Thanks MT
solar
MT -scroll down the wall there is a current post called "let the sunshine" that is a conversation on solar.0 -
solar
Sounds Like you have a drain back system. Small tank holds a reservoir of water until collectors are warm enough to heat water tank then both pumps run one through the collectors the other through a HX in the small tank. Use demineralized water for the collector side.
Joe0 -
question
Is this a storage tank or a heat exchanger? Is there a nameplate on it with the manufacturer and part #?
Some pictures would help, also..0 -
I will find out the name tomorrow I can't get pics because I don't have a digital camera yet sorry.0 -
Carl PE
can't find let the sunshine!
hey Jim I couldn't find let the sunshine on that solar topic. I did a search and it didn't come up with anything.0 -
thanks carl
thanks carl! Thats what I was looking for.MT0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 944 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
