boiler blowing saftey valve
Helgy_3
Helgy_3 Member Posts: 40
Ok heres the deal. 80% natural gas boiler, cast iron radiators, and rafter tank w/ tank valve. The saftey valve is new. I bled all the water out of the rafter tank and refilled system. Customer called and said when boiler heats the saftey blows. I was there about two weeks ago. So what ever it is takes about that long to happen. This is my second attemp at repair.. Let me know what you think. Thanks.... Helgy
  • Big Ed
    Big Ed Member Posts: 1,117
    Safety
    1. Check ato see if the tank is filling up again could be loosing it's charge . Hole or leaky snorkel.
    2. Tank too small for system
  • John Cockerill
    John Cockerill Member Posts: 94
    What is the supply water pressure control set at?
