Buderus Help Picture
Larry_10
Member Posts: 127
hay guys dose this look ok to you all I will give you all new pictures soon of the complete boiler piping
On the left: domestic hot water is high. Hopefully you have a mixing valve on the domestic hot water side.
The boiler looks fine if you using the R2107.
PATRIOT HEATING & COOLING, INC.
hi Ted the blue is the r2109 and that is the boiler temp
I was trying to see if it was ok that the boiler temp dose not quite match the water temp on the other gauge and I was wondering if my pressure looked ok for 3 zone system
1 baseboard and one hydro air and one dhw
g115 28 with lt 160
thanks0 -
Roosterboy
Your getting temperature readings from two different places. The 2109 has its sensor ( if installed correctly) in the boiler inself. The gauge 'appears" to be installed in the manifold, where if there is no flow you would not see the temp of the boiler. If there is flow it should be a little closer. Remember also that all gauges are not alike.
Scott
- 86.7K THE MAIN WALL
- 57 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 939 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
