Glass Gauge Water Boiling
Brian T
Brian T Member Posts: 2
I live in an old 19th century house which uses a converted coal boiler to provide steam heat. I have found that the only way I can get the second floor to heat is to crank up the thermometer, however doing so causes the water in the glass gauge to boil. Is this a problem, and can anyone suggest a more cost effective manner to get heat upstairs. Thanks in advance!
  • Big Ed
    Big Ed Member Posts: 1,117
    Gauge Glass
    Turning up the thermostat will make all the water in the boiler to boil . If the water is bouncing in the glass then the boiler water needs to be skimmed...
    Do you have one pipe steam system ?
  • Brian T
    Thanks for the reply Ed. I have a two pipe system. All the radiators will heatup at the high temp, but dont stay warm when i return the thermostat to 68.
  • Big Ed
    Heat Loss
    The second floor has a higher heat loss then the first floor. Heat loss has to do with the amount of out side walls,ceilings,windows and insulation.
    Since you say every radiator heats up a the same time your system is fine.
    I would look to choke the first floor or unrestrict the second to balance..
    First make sure upstairs radiators are unrestricted . If radiator covers are used make sure they designed for maximum heat out put.....
