Vapor/vacuum system
Jeff_45
Jeff_45 Member Posts: 1
Problems with heating system in a older house. Two pipe system with no traps, radiator piping supply and return both at bottom.Coal boiler replaced with smaller gas boiler. Hartford loop connected above boiler in steam header is one problem. Steam trys to heat both ends of radiators which heats poorly($3000.to $5000. a year gas bill. Need imformation on this one. Thanks
