New fittings....
Weezbo
Weezbo Member Posts: 6,231
Shark bite *~/:) it is way to simple :) i may give a couple few of them an audition on one of my convector headers :).........the orande c is a tool it clips over the cpvc pex or copper, then by pushin it at the fitting where it shoulders it releases the internal Teeth so it can be turned or for removal of the pipe altogether.
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
    Bite this...
    Nibco and Victaulic have joined forces to produce the new NVent push on fittings.
    Anyone want to buy a slightly used ProPress kit???
    Guess I'll have to EBay it soon, before the industry catches on...
    ME
  • Weezbo
    Mar k :) lets hope the glue holds a while longer :)
    the glue copper together stuff LOOKED real good now,....i go back and check again:( not too hot. I think these push fittings (provided they hold water :)) eh m mm... :) ... look like brass pro press with the advantage of actually dialing them in altogether different directions after a fitting has been made...now,That works for me...it is easy to get them loose and back out ... the only thing that sorta is a concerne,..how does that play in a freeze up of a home when you cant determine what went south in the equasion....
  • CDM2
    CDM2 Member Posts: 18
    Your ProPress
    Hey Mark,
    I have a dealer looking for a used ProPress. Let me know when you are ready to sell it.
    Dean Meece
