vertical check valve
Wayco Wayne_2
Wayco Wayne_2 Member Posts: 2,479
that needs a vertical check valve on the return. The return is a tree with 4 returns teeing in and the bottom one is the indirect. I foresee ghost flow in the Summer. The flow is going downhill. Do they make spring loaded check valves at 1 1/4" that would work in a hydronics system like that? Thanks for any help. WW
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=255&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
