% Savings Steam versus modulated hot water
Steve Garson
Member Posts: 191
This is a repost with a different twist:
I have a 70 year old Burnham Steam Boiler with modern oil burner. I burn around 1100 gallons a year. The steam heat is even and the water loop makes no noise. In short - it works fine, although I seem to be adding a lot more feed water this winter. The boiler heats the thin tube radiators with steam and a room with 30 feet of baseboard. I also have a master suite heated with radiant floor through a Bradford-White water heater.
If I replace the steam boiler with a modern boiler, installation costs will be lower, but steam is not as efficient as water. Anyone able to help me with this?
Converting to water, I would use the same radiators, but installed new feeds and returns. I could also move the radiant to a more efficient boiler and leave the water heater for just the domestic HW.
Without consideration as to the cost of installing one approach versus the other:
Does anyone have a sense of what % savings can be expected so I can make a well informed decision?
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 943 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
