Munchkin Electrical Schematics?
Dunwell
Dunwell Member Posts: 20
Hey,
Does anyone know where I can find the electrical schematics to wire a Munchkin 140M? My plumber is doing the piping, etc., but the electrician does not even know where to begin with regard to the wiring. He spoke to a Munchkin rep. and ended up being more confused than ever.
Any help please?
Thanks,
Dunn
  • munchkin-man
    munchkin-man Member Posts: 247
    The wiring is on the inside cover of the unit and manual
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    As Jeff said,
    The manuals have all the wiring diagrams. Makes me wonder though....If the electrician couldn't find them, how well are the boilers piped?( HINT, KEY TO MAKING THEM WORK RIGHT!!!!) Just thinkin out loud. Chris
  • chuck shaw
    chuck shaw Member Posts: 584
    Also,
    all the wires are marked, as to where they have to go....CH HOT, CH NEU, TSTAT, etc.
    Chuck
  • Dunwell
    Thanks guys, but...
    ...I was confused. The electrician was not clear on how to wire all of the outside elements to the boiler. The system has 5 Grundfos circulators and other items that need to be connected to the boiler. This is what he was confused about. He spoke to the Munchkin rep again and he talked him thru it (at least that's what he told me).
    Thanks again,
    Dunn
  • zurnie
    zurnie Member Posts: 8
    All you need is a 5 zone pump controller, Therm's wire in on the top and pumps on the bottom,
