two loop systems
Mark_42
Member Posts: 2
My water heating boiler has two loop systems. one supplies heat for upstairs and the other for basement. One expansion tank is installed on the pipe for upstairs zone. the expanison tank is not installed on the main pipe (common pipe). that is to say, the expansion tank is not shared by the loop system for basement heating. Does the basement zone also need an expansion tank?
expansion tank
Can the basement loop still "see" the expansion tank? Are there any flow-checks or zone valves in-between the basement loop and the expansion tank?
As a guess, without seeing it, you're probably okay, if the expansion tank were completely blocked from the basement zone, you would probably pop the relief when just the basement zone called for heat.
That being said, and again without seeing it, I would further guess this could be repiped and set up better. Is the system noisy? How is the heat delivery to the zones? What's the pressure gauge read?0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 943 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
