Weil Mclain Boiler
tim_20
tim_20 Member Posts: 41
I have a customer with a weil mclain boiler two zones that he doesn't use very often he heats with a pellet stove and he has one pipe which keeps freezing and he wants to add glycol to system its about 12 years old ,will this harm a weil mclain boiler and what is an ideal mix. thanks
Tim
  • David Sutton_5
    David Sutton_5 Member Posts: 87
    no- burst
    > thanks Tim
  • David Sutton_5
    no- burst
    its ok to run in the wm and mix it 50/50 you will be fine..David
  • Mike Reavis_2
    Mike Reavis_2 Member Posts: 295
    Use Propylene Glycol based anti-freeze
    The other stuff can eat the seals. Be sure the boiler is piped so that you avoid flue gas condensation. See the manual for piping diagrams to help prevent FGC. Mike
