Building heating with a domestic water heater
Milenius
Member Posts: 1
I want to do summer heating with a domestic water heater. I plan to use a double wall heat exchanger to transfer the heat from domestic water to the heating hot water loop. Since most commercial water heaters don't have taps on the water tank, I plan to use tees at the inlet/outlet to the water heater.
Is this possible? What sort of valving arrangement will I have? There is also a domestic water return loop.
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
