Make Up Water
Dan_20
Dan_20 Member Posts: 1
I purchased a home and the previous owner was a handy man of sorts but tried to save money quite often; on my hot water boiler he did not install a make up water system, I have been adding make up water manually. What are the components of an automatic make up water system and about how much will they cost me?
  • Uni R
    Uni R Member Posts: 663
    Make Up Water
    You should first find out why and where it is losing water. It shouldn't need any added water under normal operation.
  • eleft_4
    eleft_4 Member Posts: 509
    Dan,
    Where is the water going that you need to make up?
    al
  • Weezbo
    Weezbo Member Posts: 6,231
    Manually anualy?...or daily?
