2 pipe direct return
STEVEN MARKS
Member Posts: 154
I have a 2 pipe direct return. The mains are 1-1/4" and the branches to each radiator are 1/2". The longest run is about 130 ft. The radiator on the longest run does not heat. Based on the longest run I know I need a pump that can overcome 8 ft head. How many GPM do I size the pump for at 8 ft of head? 1-1/4" pipe is good for 14 gpm. Do I size the pump at 14 gpm @ 8 ft head? Heat loss for the house is 80,000 btu. Do I size the pump at 8 gpm @ 8 ft head? This is a 2 pipe direct return with no balance valves at radiators. I have seen this system many times in peoples homes working without any problems except this one. Please help with pump sizing or other suggestions.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 943 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
