Fire Box Kohler 22
Paul_38
Member Posts: 4
Hi,
Anyone know where I can obtain a new replacement fire box for this boiler ?
Paul
Paul
If you can't find an \"exact replacement\"
one of the Lynn kits will probably work OK. We need to know whether it is a dry-base or wet-base boiler, what type of burner is in it, and what the firing rate is.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
Fire box Kohler 22\" Boiler
This is an oil fired wet base boiler. The firing rate is: 1/gal./ hour.
Paul0 -
O-B-S-O-L-E-T-E,
it's a Lynn Quickee or an IPC Bathtub or nothin!0 -
I like the Quickee
I've used quite a few of them. They're very well made and install easily, and will outperform any old-style chamber. You'd probably want the #1001, or if that one's too big to fit inside the boiler the #1004 will handle 1 GPH.
If your Kohler doesn't have a flame-retention burner, now is the time to upgrade. You could probably lower the firing rate by 20% or so and get the same heat output. Ask Firedragon or me how we know that!
Consulting0 -
Kohler 22\" Boiler Firebox
Thank you very much for the information.
Could you please steer me to a source of information for Lynn quickee products , like the ones you mentioned, #1001 and #1004. I would like to see some data, especially dimensions.
Thank you.
Paul0 -
source of information for Lynn quickee kits
Thank you for the information.
Could you steer me to a source of information on the Lyn quickee kits #1001 and #1004 that you mentioned.
Thank You.
Paul0 -
Most heating wholesalers have or can get them
you didn't say whether you are a contractor or not- if not, your contractor should be able to get them thru the wholesaler.
Consulting0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 943 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
