Radiator Thermostats
Robert Beesley
Member Posts: 1
We have a residence with six hot water radiators I would like to control individually for mother-in-law comfort. Found that Bell & Gosset no longer have them available. Found Danfoss units can be ordered but do not know anything about quality, etc.
Any comments from your professional group will be appreciated re: effectiveness of control (all on one floor); quality of unit, mx concerns, etc.
Other manufactuers' names will also be welcome.
Homeowner
Homeowner
Never
Never had a quality issue with Danfoss. I would not hesitate to install their products.
You could also look at Honeywell-Braukmann and Oventrop. Here are some links[I hope}
http://www.honeywell.ca/braukmann/product_list.htm
http://www.hydronicalternatives.com/html/oventrop.html
http://www.danfoss-randall.co.uk/default.asp
http://www.danfoss.ca/products/pdf/TRV_sales brochure.pdf0 -
rad thermostats
Ditto on Bill's answer. Danfoss is good stuff. But, if you're a homeowner, make sure and check the piping layout first, before you spend the money. Certain piping scenarios don't lend themselves to these valves. In a loop system, shutting off one will shut them all off. You didn't mention what kind of system, so this is just an "in case" heads up.
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
