P&S
Sweet
Member Posts: 31
When piping from one pump system with on/off boiler to primary secondary does any one see a problem with running both circs to operate off the one relay that currently operates single pump.
If the
relay is rated for the start load of 2 circulators I would not think of it as a problem. I would not do it on my jobs as I do not believe it to be good practice. Best Wishes J.Lockard0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
