steam indirect
Mellow_2
Member Posts: 204
Using a steam boilers condesate water to heat an indirect we need a bronze circulator but what kind of indirect? A steel indirect will get eaten away right? so would copper be better? What would be best? thanks
i just...
did one the summer. It was a Superstor Ultra, cupronickel HX. I usually use Superstor contenders but right on the tank next to the HX it says not to use on an open system. Amtrol boilermate, Vaughn Top performer and Crown Mega stor would also be compatible. A WM/Phase # would also be poor choces for your application due to the steel tank/ HX. kpc
If you want copper
Everhot
www.tfi-everhot.com0 -
ok
thanks for the responce. what would be materials to look for? It sounds like they do not make indirects for steam boilers or should I look for a copper coil.... I do not know of a good copper coil tank. any ideas0 -
Kevin said it, Amtrol or Vaughn one has a poly liner and one has a stone lining, You pick0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
