A lot of radiation, small boiler.
![[Deleted User]](https://secure.gravatar.com/avatar/79f3d3af4c8d6fdbe2c5a56d27213987/?default=https%3A%2F%2Fvanillicon.com%2Ffc08b6b2e799a045d210ba96efa25a68_200.png&rating=g&size=200)
[Deleted User]
This is a hypothetical question. I may be dealing with a situation similar to this in the near future. A home has a very old existing boiler with a doe rating of 140,000 btu's. It has roughly the same amount of radiation, it's all cast iron baseboard. A heat loss tells me the home only needs 50,000 btu's. What are the consequences of installing a properly sized boiler on such a huge amount radiation? My concern is condensation problems, Im doubtful the boiler will reach a temperature high enough to prevent this. Would a small bypass between the suppy and return be a possible solution? Any input would be appreciated. Thanks. Mike.
Why not
use a condensing boiler? Then you could modulate the output, outdoor reset, and not worry about cool return temperatures.
And get high efficiency to boot
hot rod
If you don't use a condensing boiler
use the bypass. This should keep the boiler hot enough. Bet their fuel consumption drops way off, no matter which boiler you use.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
Thanks for the input
Thanks for the input. I never got to actually look at the job. The customer has decided to do it himself. He'll probably use a 1,000,000 btu boiler. Mike.0 -
bigger is better-----right------next year someone will have to come in and knock off a few sections-replace broken pipes etc... job security0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 943 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
