Need Hot Water union 90s with radiator nipple.
Kevin H.
Kevin H. Member Posts: 2
I am in Columbus, Ohio, can't find any union 90's for hot water radiators. I need the nipple with the union joint on the 90 (male threads), then standard female connection to the rest of the system. The big supply houses in town can get the valves but can't find the 90s. I am looking for three (3) 3/4, and three (3) 1 1/4; again each with matching union nipples to screw into the radiators so I don't have to worry about leaks from a poor fit to something machined 60 years ago. Thanks in advance.
    Steamhead Member Posts: 17,636
    They're still made
    but I can't remember who made the last ones we got. Call around to different supply houses, especally those that also serve the East Coast. They may be able to point you in the right direction.
    Consulting
  • Kevin H.
    Any suggestions on east coast supply houses...
    Thanks for the response, since I am not out there, do you have any suggestions on any east coast supply houses... Thanks in advance...
    Kevin H.
  • Mike Kraft_2
    Mike Kraft_2 Member Posts: 398
    Just bouhgt .....................
    13 of the 3/4" ones.They are brass and made in Taiwan.I'm not real happy with the screw fit.The male end buries itself in the radiator bushing.I used teflon and paste dope.Time will tell.I purchased them from RJ Walker Supply in Scarnton PA.Tel#570-344-8221.I would also try Avco Supply.They are on the net.They're in Levittown PA..Also try Eastern Penn Supply Company (EPSCO) in Scranton PA.(also on the web)
    cheese
  • jim lockard
    jim lockard Member Posts: 1,059
    R.E. Michels
    Should have or can order them, you might try Ferguson Ent. they should be able to get em. Best Wishes J.Lockard
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Kevin,
    Our supplier carries them with the Legend name. See if any of the local suppliers deal with Legend and have them order them.
    Like Cheese said, the fit is O.K. but not the best and I've found that the dope/tape/dope method works the best with them. Chris
  • Bill Nye_2
    Bill Nye_2 Member Posts: 538
    Call my supplier
    My supply house can UPS'm. Call Shetucket Supply 55 North Main St. Norwich Connecticut 06360 860 887 3571 Ask for Bob or Reggie, you can tell them I sent you
  • Dave Stroman
    Dave Stroman Member Posts: 765
    I use radiator valves on both ends. I can get the valves for about half the cost of the 90's.
    Dave in Denver
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
    Watts
    is the parent of the Legend brand. Look in a Watts hydronic catalog.
    ME
