tenent thermostat
pat_3
Member Posts: 89
does anyone have a recomendation for a reliable t-stat that will give tenent no control beyond landlord settings,maybe something with a coded lock-out feature?thanks in advance for any responses
Tenants T-stat
I have used the "Accu-stat" it uses a preset bulb to control things I'll see if i can more info for you0 -
tenant thermostat
Pat
I have used a tekmar 076 indoor sensor in the tenant area and a tekmar 508 thermostat in the mechanical room or any area that is not accessed by the tenant where you can adjust the temp for them.0
