Pipe / furnace noise
kevin_20
Member Posts: 2
My plumber installed a new gas-fired Burnham spacemaster and piping for a 3 story extension on my house. The furnace is on the second floor, and has 3 zones. Each zone services 6 raditors- 2 each on the 1,2 and 3 floors. Five radiators are baseboard cast iron - one is a baseboard tube. (See attached file for diagram)
My problem is the noise level. The cast iron radiators sound like they have air in them. I have bleed the radiators and there is very little air. The furnace when it is on sounds like a pump being primed. Both the radiators and the furnace are extremely LOUD, to the point that it wakes us up at night, even though it is on a different floor.
My plumber who installed this looked at it and says it is normal. Is this the case?
What kind of
pumps (make and model) do you have?
re: pumps
Hi Alan,
The circulator pump was builtin to the unit.0 -
I would suggest
Go over to www.oiltechtalk.com and post a message for Glenn Stanton. He work's for Burnham and can probably help you with your problem...0
