Valve Capacity
Sky123
Member Posts: 2
I have an old American Standard Oakmont Model 86 Boiler.
The nameplate list Max. net sq ft of radiation and also
Valve capacity. What is valve capacity?
> Boiler. The nameplate list Max. net sq ft of
> radiation and also Valve capacity. What is
> valve capacity?
valve capacity
I believe you are referring to the safety valve rating for that boiler. Make sure they match up or assume the liability.
Valve Capacity
Thank you for the reply.
The nameplate is marked 20.2 or 202 with no units.
If it refers to safety valve capacity i'm assuming its in #/hr.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
