spitting
i had a customer call me today because they had their bathroom radiator spitting water.. i heard a lot of gurgling in the radiator.. its a 2' box convector.. i had the system run till i heard a lot of gurgling, shut the valve and disconnected the radiator.. i emptied water that would equal too about the entire radiator size.. i reconnected it, put the customers hoffman straight air valve, pitched it and was great.. 8 hours later, they called and said there's more water spitting than before.. what could this be? should i just let the system run with the line open to flush any existing water in the system? this is the only radiator thats spitting water and its the last on the run... thanks
