Control wiring
Andre
Andre Member Posts: 11
When converting a boiler from a tankless water coil to a indirect water heater, is there any modification needed to be made to a L8124A relay before adding a three zone SR503 switching relay. Not using a cold start
  • Firedragon_4
    Firedragon_4 Member Posts: 1,434
    Nope!
    The 503 style relay, regardless of who makes it, will align to the L8124 and you'll get great operation if everything is wired right and set correctly, FACT!
