Two cold rooms
David Powell
Member Posts: 1
I have a two cold bedrooms. The hot water radiators have been vented to purge the air, but the top 3/4 of the radiator still never get hot. The supply and return pipes for each radiator get very hot, so it seems the problem lies with the radiator or radiator valve. Is there a way to inspect the valves for proper operation? Thank you..
Cold rads
Does the hot supply connect to the top and the return to the bottom of the rads?0 -
Circulator too big?
This can push water thru the radiator so fast it never reaches the top.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
