Paging Glen Stanton
TGO_54
Member Posts: 327
Hi Glen,
I have a queston on clearance for the V9 boiler - are you online today?
Tom
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=278&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Tom
I think Glenn
is on vacation till after New Years .
Here's the link to the .pdf site for the V9 , like Glenn always says - hope this helps .
http://www.burnham.com/pdfs/CurrentPDFfiles/V9-I&O.pdf0 -
Thanks Ron
> Here's
> .pdf
Thanks Ron
I guess I'll call Burnham in the AM
Tom
I am on vacation but I'm still checking in from time to time. What is it you need to know. Our offices are closed on Monday for the holidays. Let me know what you need and I'll be glad to oblige.
Glenn Stanton
Manager of Training
Burnham Hydronics
www.burnham.com0 -
Hi Glenn
Sorry to bother you on vacation. I am looking to use a V-9 for an oil fired steam job rear flue. The manual states that you need 6 1/2 feet from floor to ceilng for the boiler. I have some 4" Steam mains that will run across the top of the boiler 59" off the floor. If the boiler is rear flue will it be a problem? Does the top flue canopy need to be removed for maintance? I'm in the office if you would like to call.
Thanks for your help.
Tom
Tom
It's always best to be able to clean the top of the sections as well as the flue passageways. Since the top of the jacket of the boiler is already 57" this will make things rather difficult. You would have to remove the top jacket panel anyway to get to the canopy and doing so will only require a couple of inches of play, so you may be alright. The canopy itself is recessed down inside and you should be able to work it up and out provided the entire area above is not full of mains. If your mains are that low, you will probably want to consider a dropped header for this job. Too bad you don't have a pit to put the boiler in. Hope this helps.
Glenn Stanton
Manager of Training
Burnham Hydronics
www.burnham.com0 -
Thanks Glen
> Glenn
> Stanton
> Manager of Training
> Burnham
> Hydronics
> www.burnham.com
Thanks Glen
> Glenn
> Stanton
> Manager of Training
> Burnham
> Hydronics
> www.burnham.com
Thanks Glen
I will take a copy of the installation manual and a ruler to the job and verify that I can get the flue collector off. Thanks for taking the time on your vacation.
