No heat in one zone... darn leaky valve
George_15
Member Posts: 24
One of the 6 zones in my apartment building had no heat. Got the call on Christmas Eve at 5:30pm... (ughhh). Went there and found the floor by the boiler wet and the return pipe for that zone cold. It looke like the spighott where you bleed the zone was leaking and i guess air got in. So I bled the lines, filled up the boiler to proper psi., tightened up the valve on the spighott real good and put a drain cap on the spighott and all was fine. I guess that the washer at the end of the stem is worn causing me all this grief. I rather not start a project like this though since it is too cold and you never know what problems arise when i tear apart the valve. Any ideas or suggestions or similar expereinces?? Thanks!!
Float Bleeders
I seen on one job where floot bleeders were installed above the ciirculators on the return and a air scoop on the supply. Low pressure system , it was a bank whith the boiler on the top floor. Passed air right through the boiler which you guessed, was short lived...0
