domestic hot water
cph_2
Member Posts: 1
I am looking for a site where I can find out about a boiler mate. problem is i am running out of hot water i am thinking that the pump on the boiler side is to small it is a 007 buy taco dhw is on priority it is a 41 gallon and it runs out in about 18 minutes any suggestions.
The pump isn't too small... it maybe bad, have someone who knows what they're doing check it out for you.0 -
chances are
It is not the pump. The age of the tank is an important piece of info. The reason I say this is that the Amtrol Boilermates have a coil that is much like a tankless boiler coil. It does not have a smooth surface and because of that it tends to pick up a lot of sediment. As water is heated the elements in water come out of solution and will adhere to the coil surface. This will eventually insulate the coil. This will cause the exact symptoms you are talking about. If your coil is beginning to "plug" it will get worse.0 -
chances are
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 66 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 43 Industry Classes
- 48 Job Opportunities
